Mounted the AirGizmos panel dock for the Garmin AV8OR GPS.
Mounted the Westach quad engine instrument which show EGT, CHT, oil pres, and oil temp. To the lower left of it will be a switch to allow reading any one of the four cylinder EGT's and CHT's.
To the left of the GPS will be switches and circuit breakers.
On the right of the panel will be a slip indicator and panel mounted compass. I'm also considering a VSI on the upper right of the GPS.
Tried the panel with the LED strip illumination. All the guage information is clearly visible with no shadow problems.
